Ecoboost 1.0 st line
Is there an issue with the cam belts on this particular model when high mileage occurs and if regularly serviced does this helps with the cam belts??😊
There is a problem with the wet cam belt (and wet oil pump belt) on all 1.0 Ecoboost engines.
You need to be thinking of changing yours at the end of this year. The maximum expected life of the wet cam belt is 10 years.
