Fault code p2599 , p2562
Would anyone know what the fault code p2599 ,p2562 is ?
I have a fiesta 1.6 tdci. I was driving and it came up with Service engine. It had a spanner on the dashboard and car went into limp mode. I plugged in my scan tool and it came up with the fault code p2599. i had a fault code p2562 a few months ago but that went away. When I have looked online both codes p2562 and p2599 are turbo boost sensor fault codes. Would this be right and is it and is it an easy fix? Thanks.
Same question as last year, so I suppose the answer will still be the same.
P2599 = Faulty turbo position sensor. [Sensor A Performance - Stuck High]
P2562 = Turbo boost control position sensor circuit.
Would I need to replace just the sensor or would I need to replace the turbo ?
1 minute ago, Jordan1993 said:
Would I need to replace just the sensor ?
It might not solve the problem but, it is by far the cheapest and easiest thing to replace, rather than start removing the turbo.
