Ford Transit Connect DashCam Fuse Connections
Does anyone know where I can plug a fuse wire in for my dashcam?
My Ford Transit connect has the Passenger Compartment Fuse Box and I want to use a fuse that stays on 24/7. Thanks
Fuse Number   Fuse Rating   Circuits protected
F56   20A   Fuel pump
F57   -   Not used
F58   -   Not used
F59   5A   Passive anti-theft system transceiver
F60   10A   Interior lamp   Driver door switch pack   Glove compartment lamp   Overhead console switch bank
F61   -   Not used
F62   5A   Autowipers   Auto-dimming interior mirror
F63   10A   Adaptive cruise control (front sensing module)
F64   -   Not used
F65   10A   Liftgate release
F66   -   Not used
F67   7.5A   SYNC   Front display interface module   Global positioning system module
F68   15A   Electric steering column lock
F69   5A   Instrument panel cluster
F70   -   Not used
F71   10A   Heating control head (manual air conditioning)   Dual automatic temperature control
F72   7.5A   Steering wheel module
F73   7.5A   Data link connector   Battery backup sounder
F74   15A   High beam headlamp
F75   15A   Front fog lamp
F76   10A   Reversing lamp
F77   20A   Washer pump
F78   5A   Ignition switch   Ignition switch (vehicles with keyless starting)
F79   15A   Audio unit   DVD navigation system   Touchscreen   Hazard flasher switch   Door lock switch
F80   20A   Moonroof
F81   5A   Radio frequency receiver   Interior motion sensor
F82   20A   Washer pump
F83   20A   Central locking
F84   -   Not used
F85   7.5A   Ignition switch
F86   10A   Airbag module   Occupant classification system   Passenger airbag deactivation indicator
F87   -   Not used
F88   25A   Body control module KL30 supply
F89   -   Not used
