Things to look for mk2 focus st225
Hi, looking at upgrading from my mk7 fiesta to a mk2 focus st 225. Any common problems to keep an eye out for when viewing? cheers
From my own experience the bodywork is standing up more or less, had an oil diaphragm unit fail with shorted heater element then couple of driveshaft boots failed/perished usually on drivers side as it’s more exposed. Plus an alternator packed in followed by the Ford re-manufactured replacement only a month later 🙄
My pre-facelift succumbed to a cracked liner near the end of its warranty, I’d say these days lot of cars have either had block mods to prevent this or have already suffered failures and been fixed.
Some other issues like boot water leaks aren’t unique to the ST models so lot of info already in the Focus section here.
Best thing to keep an eye out for is petrol stations, like a BEV, you'll need to plan for where they are
perfect cheers, have heard quite a few things about these cracked liners so will defo keep an eye out for that and try go for one that has had a block mod done
I've had one on my 2008 ST
I get nearly 33mpg out of myST !
Check to see if the hatch glass has the "gutters" fitted on either side (42410).
Without these, every time I lifted the hatch in rain, it tipped water into the boot.
I think the rain channels were factory fitted to facelift models, possibly came in with late pre-facelift cars. Easy enough to fit if needed.
I don’t do mega miles in mine so don’t keep too much of an eye on fuel consumption. Running RS injectors which will distort the calculations for what the car is telling me and I never tried to see how accurate the mpg readings were before the injectors were changed.
