Help needed
I have a mk3 2007 ford mondeo and the passenger front door wont unlock or open and is stuck shut. How do I get it open
If it won't open from the inside then there's no easy way to get it open.
You can try thumping the door around the latch area while pressing the unlock button.  If there's a poor connection in the latch module the shock can make it reconnect briefly.
Only other option is to remove the interior door panel, potentially having to damage it if you can't reach all the fixings with the door closed.  Once the door panel is off you have access the latch, and may have to damage that to remove it as well, depending on the way it's failed.
