p0036
fault code p0036 on 2018 fiesta ecoboost is ther an easy fix? mot is due.
That code is for the second lambda sensor.  The one fitted after the cat.
Generally, it will require a new sensor, though as with any electrical fault, always worth checking plugs and wiring first.
thanks,any one in particular i should buy?
The genuine Ford one will definitely work correctly.  Though costs around £100.
Genuine Ford Fiesta Mk8 1.0 EcoBoost Exhaust Gas Lambda Sensor 2014- 1871326 | eBay
You could try an aftermarket one at around half the cost, but obviously risk it not being made to exactly the same spec.
Lambda Sensor Post Cat 0258986782 Bosch Oxygen C1BA9G444BB C1BA9G444BA LS86782 | eBay
Please double check with the seller, using your reg, before purchasing.
A blown fuse is a simple fix. Replace it with the correct amperage fuse if necessary.
a small world cup
I'm not familiar with the 2025 Ford model Lynch, is it electric ?
where is the fuse for the sensor?
There is no fuse.
If you are looking at the post from @larima33 then don't.
