Mk4 focus CC/ACC coding
Good afternoon everyone! I want to know if i could program CC or ACC with forscan on my december '18 focus sedan. The car is not fitted with any cruise control at the moment, only speed limiter, speed sign recognition and front colision assist.
Could i program any? Or automatic high beams using the windshield camera?
Have you fitted the steering wheel with the cruise control buttons ?
With the correct steering wheel you should be able to turn on standard CC using FORScan.
Details for the Focus Mk4
You can only program ACC if you have front radar
You can program CC but will need to change the switches on the steering wheel to support, then program the switches and activate CC
You can activate Auto High Beam only if you have the correct level camera fitted AND auto headlamps
Lots of posts on the FORScan Forums about activating all these items
i do have rain sensor and automatic headlights, halogen, i do not know if the radar is fitted in front but i am going to check, since i have heard that the models before march 2019 would have it already fitted
also, i did not change the buttons on the steering wheel
You need the buttons and config them, then activate CC
Follow unofix's coding, above, and auto high beam will work at 50KPH and above, if you have the correct camera
can t i make it work on the speed limiter buttons?;(
No.
As above
The signal from the limiter button will only work the limiter, you need to source a CC with limiter button, configure the buttons to the car then turn on CC
