Transmission fluid
I have a ford fiesta (automatic) mk5 1.4 2004 and I am trying to see why my shifts are slow and sometimes they even lag . I want to check my transmission fluid but for some reason the transmission fluid is on the same place with the brake fluid . How can I coach my transmission fluid in order to see if I need to change it or not ?
The 1.4 Fiesta uses a semi auto transmission. The same transmission that is fitted to a manual car but with a shift actuator controlling the gears and a clutch actuator for the clutch.
There is a know issue with the shift actuator assembly. Watch the attached video, the important parts are 17:00 - 18:00 mins and then at 18:50 mins. The video example is when the unit seizes completely, which yours will likely do if it has started slow shifting.
