Cruise control
Good night, I have a Ford Focus 2009 2.0, powered by gasoline, manufactured in Argentina and sold in Brazil, I cannot access the PCM module to activate the cruise control, the PCM module does not appear to be configured in Forscan, when trying to access it through elmconfig It does not complete the reading, it returns an error, in the other modules it is already activated and the buttons are working after carrying out a test, I would like a solution to this problem, thank you very much in advance.
It could be your lead.
Check your connection settings
Delete profile
Reconnect to car
I'll try, thanks!
Good evening, stopping by to give you feedback,I was using ELMConfig0.2.17b, which was unable to access the PCM module, so I changed to ELMConfig0.2.17c and the problem was resolved, I was able to enable the cruise control on my Focus 2009 2.0 gasoline, I've already done the road test and it's working 100%.
