One black sooty spark plug
Hi
I have a standard 2.0L Pinto in a MK Indy kit car and I am getting one black dry sooty spark plug always number 3, running on a weber 32/36. I have tried
Swapping plugs
Swapping leads
Distributor round 180 deg.
removed PCV valve
Had block re-bored, skimmed, new pistons and rings, head skimmed, new valve guides, unleaded inserts, new valve oil seals
only using E5 petrol
Still No. 3 black and sooty mis-firing all the time
Any help appreciated ............ getting frustrated
John
Check valve clearances
Check compression on number three
Check dizzy cap and rotor arm
If you're running E5 set ignition timing to standard 4 star (original), not retarded for unleaded
Thanks DaveT70
Checked valve clearances and compression both ok, Cap and rotor arm look okay but will swap out and advance the timing
