Indicator issues
Hey ,
I have a Ford fiesta 2009
my indicator is not work as it should
it will be fine , then only flash once on the dash board and then stop working
if I turn the car off and in it will then sometimes correct itself?
to confirm when it is not flashing on the dash the car light is not in either
any ideas before I pay the earth to get it checked out !
If you don't have any diagnostics, the cheapest and easiest part to try replacing first is the indicator stalk.
If it's not that, it may be a fault with the BCM (fusebox) but that's more involved to replace.
