Ford fiesta 2007 diesel 16TDI
Hi All Hope you can help (first time on a forum) car lost power whiled driving  i have a engine and oil light come up on dash yet ( oil level is good )Diagnostic came up with PO500  VSS/ P1934 which i believe is Vehicle speed signal and U0073 Comms , i have checked the ABS sensor on all 4 wheels using a Muiti meter  front  sensors on continuity show 596 but when i spin the wheel i get no volt reading on both side of car ( does this mean both ABS cable are faulty ?) , Loom back to TCM reads 12v.
Question
is there a VSS on the transmission that i need to find or is it just ABS to wheels?  and if so does the above mean i have 2 faulty sensor at front , and how do you check the back abs as both wheel go into one connection with 2 pins for left wheel and 2 for right ( what setting do i set meter to?
Any help would be appreciated thanks
