2012 fusion rear light lamp holder
Hi.
I'm having trouble finding a Fusion 2012 rear light lamp holder. Will a fiesta rear lamp holder fit ?
I'm giving away for free a pair of brand new genuine Ford Fusion 2012 rear lamps. Just reply to this post before the 4th July 2024. After that date they will have been scrapped.
Hi.
hi i suspect that your problem is water getting in the lens past the central foam seal and rusting the contacts, i,ve had 3 fusions and on all i drilled drainage holes in the bottom of each lens, the bottom light is the fog light and i had to use a mini drill wire brush and sandpaper to clean the contacts and grease with  vaseline.
if the bottom contacts are too far gone all you can do is change the bulb holder side, i doubt if they are the same as the fiesta
