HVAC issue
Hello
Got a 2019 Fiesta
Has anyone experienced this fault 7 all HVAC?
Just had air con regassed and doesn't blow cold was wondering if any or all could play a part at all?
Did you gat it regassed at a reputable place, most will check service and regass if no faults found, then run and check temp at car vents.
Does the HVAC work at all?  Looks like a multiplug has been left disconnected.
Yeah it all appears to work but no aircon.
Hmm, weird.  It can't be working properly with so many sensor inputs triggering fault codes.  It may be able to run a 'default' manual setting without auto-control.  Not sure what to suggest other than checking all the plugs behind the dash.  Could try a battery disconnect reset but I really don't think that'll help here.
Sounds like HVAC control module has gone down with that many DTCs
