Rear indicator not working
Hope some 1 can help
I have a 2011 ford focus my rear indicator has stopped working changed the bulb checked the contracts still nothing
When you put the stalk down the wing mirror an front indicator bling twice as fast as normal. Also it doesn't work when I put the hazards on
Any help would be appreciated I've seen a few threads on here but none have a definite answer
A common problem is the earth tab in the side of the lamp holder gets pushed too far in and doesn't make contact.
On 4/15/2023 at 10:17 PM, unofix said:
The ground tab in the lamp holder is not protruding far enough out and is not making contact with the side of the bulb.
It just needs eased out a few millimeters with a small screwdriver.
That'll solve it...
You gotta wonder if this solved it. Probably did and the OP has gone off skipping with joy never to be seen again LOL We got any of those OPW medals still left?
10 minutes ago, StephenFord said:
You gotta wonder if this solved it. Probably did and the OP has gone of skipping with joy never to be seen again LOL We got any of those OPW medals still left?
I used to get that a lot but on Farcebook, so much now I stopped helping, just used 🙄
  • 10 months later...
I have this exact problem right now.
Thanks for the tip, I'll try this and promise to report back my results! 🙏 😁
