Key fob lock - unlock behaviour
2010 petrol 1.4 Ford Fusion. Doors open signal on dash, while doors definitely closed.Then lock - unlock issue. Traced problem to electrical malfunction. Sprayed with electronic cleaner by car lube - problem solved in 10 minutes.
I have the same problem. Where did you spray the cleaner?
