Headlight change
Hi all I have put the mark 7.5 front end on my fiesta make 7 but I need to forscan the drl on I think do anybody know how?? And same with my radio I have changed it to a Sony radio and it doesn’t work on dab
Have you added the DAB aerial?
Regarding Forscan, it should be as simple as ticking a box that says 'with DRLs'.
On this version of Fiesta, the settings in the BCM have to have 'With DAB' enabled using FORScan.
On 12/2/2017 at 4:07 PM, Luke4efc said:
So just as I post that DAB just disappears from the list when you keep pressing radio. Tried turning it off and on again but nothing. It was really strange as I was just pairing my phone up again (had DAB BBC Radio 1 on in the background) and when I went to press the radio button nothing happened, starting to think it was a dud unit. Anyway when I managed to cycle though FM,AM etc. it just wasn't there.
Decided now was the time to break out FORscan and my modified Elm327 adaptor, quick look into the IPC data and I found it didn't have DAB radio system enabled. Quick write to the ECU (and some weird stuff happening on my dash, all my gauges kept clicking as wrote it's data) and boom it's back again.
Sat here now for a good 10 minutes fiddling around with settings etc. and not gone away. I think I can call this one a victory.
Hi I changed it and there still no luck on dab it won’t find any radio stations for it
