Electrical problems
I have just inherited a 08 fusion.
The problem I have the central locking is not working it displayed the passenger door is open.
I have changed the door lock now the indicators don't work, if I push the hazard warning switch it unlocks the boot and nothing else happens.
The heated front/ rear switch's are both lit and won't turn off
Fuse box is clear of rust and all fues are good
Please help
Check for water ingress in the passenger compartment fusebox and or
GEM module.
Almost certainly water ingress of the GEM.
Disconnect the battery negative lead before investigating. You will need to fully unplug all connectors on the GEM and then remove it for inspection.
GEM module.
Is it possible to test the gem module as I have removed both but fuse box or gem look damaged?
Use FORScan to check for DTC's and to run module test on GEM
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
