misfire 09 1.4 petrol
Afternoon.
I recently purchessed an 09 ford fusion 1.4 petrol . i have just discovered that it has a annoying misfire and the engine warning light is on.
starting isnt a problem and runs fine on tick over , but as soon as apply some throttle while driving it cuts out ( low rpm ) , hesitates and often back fires . when i drive the car hard ( high rpm ) it seems to clear itself .
i have changed the coil and plug leads , plus stripped and cleaned the throttle body , still the same problem occurs .
i have ordered a set of spark plugs ( still waiting for them to arrive ).
if changing the plugs dont solve this problem , is there anything else i should check?.
was thinking that the timing belt may of jumped a tooth or a valve is choked somewhere in the intake or worst scinario valve damage!!.
any ideas!
cheers
Get it plugged in and use forscan software (or a very good quality obd reader.)
If guessing, you will need deep pockets.
Been there, crap obd scanners, guessing, asumptions.... best thing i ever did was buy a decent ftdi cable, install software and all the answers were on the laptop screen for me.
Use FORScan, it's much better at guessing than I am 😉
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
Search Tag:   FORScan123
aint got a laptop. just about tried everything now . changed plugs , leads , coil pack , cleaned throttle body . even tried running the car with the MAP sensor disconnected . just got worse . hardly will tick over when sensor is unplugged .
really struggling here.
2 hours ago, mr.t said:
aint got a laptop
What a shame you also don't have a mobile phone or you could have used the android or iPhone version
ah , i do have a samsung galaxy.
