1.6 tdci mondeo massiv problems 2012
hi, I have a mondeo 1.6 tdci that had its engine changed, same engine number, but after it was finished I drove the car home, but the car ran badly, so I did a diagnosis and deleted all the codes, then the car worked fine, 1 day later and the car goes into limp mode, and it only went 2-3000 rpm, diagnosis showed, code p0238 turbo boost sensor a circuit high volt.
p0405 -AC : Egr sensor A : circuit low.
P0098 : IAT - circuit sensor 2 #A - high voltage.
The car starts and sounds like the engine is at war. misfire - loaud knocking fra the engine max 1300 rpm aloth off white smoke from the exhaust, changed egr sensor - AIT sensor but no difference, engine light is on,what could be wrong?
