Ford focus mk2 1.6
Keep getting this code does anyone know how to fix this problem ?
That's a probably a broken wire on the alternator plug.  If you're getting an auto electrician to fix the headlight, ask them to look into this as well.
Alternator smart charge plug or wiring is broken/corroded.
The battery charging voltage from the alternator will default to 13.95V when the smart charge circuit is faulty.
Is it important to get this repaired or it’s nothing to worry about
Yes it needs repaired, or your battery is going to have a very short life.
