Urgent
Hi i have ford focus 2013 1.0 eco boost today i was driving and suddenly abs and esp lights comes up with engine light showing too and my steering wheel become stiff heavy n speedo meter is not working after these check lights my exhaust fan is giving noise even if i turn off engine the exhaust fan still spinning n make noise for couple of minutes this issue came after these lights.
any suggestions. What happened with my car?
Might be worth looking at this post seems to be a similar issue?
Thank you for sharing this . Yes i have same issue but still question is the same what is solution i don’t how much will it cost n whats the problem anyway tomorrow will take it to mechanic. Hope it will fix.
cheers
15 minutes ago, Shani. said:
 Hope it will fix....
Don't forget to report back here on result, always good to share the knowledge...
I took it to mechanic did diagnose and code was showing front wheel speed sensor Code C0034-15 . He will replace and i hope the problem will go away.
