Warning Lights only in cold weather
Morning, I have a 2015 Ford Kuga 2lt Diesel Auto. Overall it runs very well but when its cold in the mornings the ABS and Anti Skid warning lights come on and stay on till the engine warms up, then they go off and stay of for the rest of the day. The brakes themselves are fine, no problems just the warning lights. This does not happen in the summer. Has anyone else experienced this problem and if so did you manage to resolve it and how. Any help would be appreciated. Thanks in anticipation, William
If your 2015 Ford Kuga 2lt Diesel Auto has the ABS and Anti-Skid warning lights coming on only when it's cold in the mornings and then turning off as the engine warms up, the most likely culprit is a faulty ABS wheel speed sensor, which can be affected by cold temperatures and might not be sending accurate signals until the system heats up properly.
You need to get the Codes read, guessing what is wrong and replacing parts until the faults go is false economy.
Many thanks both, Now you have pointed me in the right direction I will get it sorted by my local garage, I just could not understand what was going on. Thanks again
