door handle and frost
One morning during cold weather i opened my door and the lock cover trim has broken and fallen off(door handle still intact)
managed to source a replacement online but could anyone enlighten me as to how to fit this as looking at it, doesn’t look compatible.
Im struggling to attach photos taken by my phone. any advice how to do it
Plesse see images
At the bottom of the dialogue box where you type your messages, there will be the phrase, 'choose files'. Simply click on it, and direct the subsequent file box to the photo (s) you want to attach.
Locate over the lock barrel at the top and snap on at the bottom.
The bottom should have a slot in it where you fit the key to take the cover off
Unless it's one that's attached to the lock barrel, in which case you'll need to remove the barrel, refit the barrel in the cover and refit
Thank you. Just needed to compress the images.
As you can see the shape of the key hole is round. Can’t see how i could slot the cover on
i tried to find a youtube tutorial to fit this but the only things comes up is a whole handle/door removal
It looks to me that the center plastic piece on your new cover is a duplicate of what is already fitted to your door handle? Hopefully another opinion will arrive soon...
 I agree. Just tried to take it apart but all i got is this
I personally conclude it's the wrong 'cover', but maybe someone else will have direct experience of it, wouldn't throw it out just yet!
That looks like the cover from the passenger side door handle (no lock fitted)
Thanks for this. It would make sense. The passenger  side isn’t broken so couldn’t tell if it was the same.
They only sent me one part.Apparently other one is in the post so fingers crossed the other one will fit the driver side.
Thanks again. Will let you know
Yes, that's a passenger "blank"
I would strongly recommend going to Ford and get a new one
  • 1 month later...
Would anyone be able to point me to the right direction as to how to remove one of these lock covers on a fiesta 19 plate
Just pull it.
Thanks. Are you sure? i don’t want to break it. It was expensive
Yes.  It's designed to be removed easily without any tools when the key fob battery fails and the remote won't unlock the door.
Remover kit is available 🤣
