ST line X 2021 Hi Beam
Beam on my Puma makes just about as much as no difference at all from dip.
Is this normal for these lamps or do I have an issue?
Any advice appreciated.
Cheers
If you expect to see a sudden burst of light when changing from dipped beam to main beam then you won't.
When you switch from one to the other, the lights fade up (usually around 5 seconds) , or fade down (about 2 or 3 seconds). The fade time can be adjusted using FORScan.
Hi m8
thanks for the reply, I’m aware of the fade but there is just no significant difference between dip & beam, as to the extent it makes no difference whether its on or not, though it is definitely on.
Think I worked out what was happening, my drive is on a little upslope, if I start the car on auto lights they level whilst pointing into the air🤷🏻‍♂️
stop car on street, restart, lights are fine.
whoda guessed 🤷🏻‍♂️😂
