Fiesta engine swap
Hi guys new here. After some help if possible basically my sons mk6 fiesta 2008 1.4 I replaced the engine for another one the exact same engine it’s all done but idle very badly it’s got a constant misfire revs are up and down between 800 and 900 but if u rec it and drive it it’s fine and doesn’t misfire only on idle . The only code I’m getting is p1000 which I know it needs driving to get rid of that. It starts and drives fine admittedly only drove it a short distance at the moment but idles badly it’s not the plugs leads or coil pack and there are no air leaks at all. I’m very done a compression test on the engine that’s come back good so I’m at a loss at the moment any help would be appreciated thanks
How or what are you using to read the DTC's ?
I’ve used Delphi and wow thanks
