Heated windscreen
I have a 2015 ford focus heated screen is only clearing passenger half of windscreen is it an easy fix?
Yes/No depends on the fault.
Check the fuse for the drivers side of the windscreen. If that is OK then you probably have a broken windscreen which will need to be replaced.
Check the fuse for the drivers side of the windscreen...
You do know the next question will be where is the fuse located and what number slot is it in?? 🤣
My bad 😀
