Power steering
I changed my control arm and the rack in pinion. But now have no power steering. Please help
  • 3 weeks later...
Hi, did you bleed the system off, very easy to do, best if you change the fluid, also remove the header tank & flush it out, there is a filter inside which can reduce the flow & cause the pump to overheat.
