Focus C
Hi, I own a 2014 Focus 1.6 TDCi with the LED light cluster. Unfortunately the drivers side light cluster got broken by a falling roof tile back in December. Naively and not knowing the exact type mine was at the time, I have bought a non LED cluster.
What I want to know is two things:
Will the non LED cluster operate correctly when plugged in without affecting the fuse or computer?
And if it does work can I change the non damaged cluster so the positive feed for the LED board goes to the normal bulb tail light filament instead (effectively a spare on the fog lamp on the LED type) without effecting the computer or impacting the fuse so both clusters tail lights match.
3 minutes ago, unofix said:
Oh dear 🙁
No.
The current taken by a regular filament bulb is vastly more than an LED. The Body Control Module will see the heavy current drain of the bulb as a potential fault and it will turn off the supply to that light.
