Ford focus mk3 tpms light
Ford focus mk3 had 3 tyres swapped now tpms keeps coming on and off intermittently garage saying all sensors working fine any idea??
Have you reset the TPMS system ?
Are they the original TPMS sensors?  in which the batteries will be failing by now. They only last between 7 and 10 years.
Had 4 new sensors fitted 12 months ago
Good, and have you reset the TPMS ?
No have cleared via settings but it keeps coming back
Set all tyres to the correct pressure and then reset the system via the instrument cluster by pressing and holding the TPMS reset until complete.
If that fails then you need to use FORScan to see which of the sensors is not being read correctly. You might have to use the relearn tool.
