Sat Nav upgrade - display now showing in km/h instead of mph
I upgraded the basic 3 line display to a 5" sat nav (FCDIM) unit and now the odometer and sat nav is in km/h. There is an option in the settings to change from km/h to miles but although you can highlight miles, you can't press the OK button on the radio fascia. Does nothing.
Does anyone know which Forscan setting it is to swap between km/h and miles/mph instead?
You need to change the screen size to 5 MFD then you can change it back to miles.
So in Forscan under Central Config?
This worked, thanks!
