Halogen low beam headlights to projector
Would it be a plug and play situation if I wanted to install headlights with a projector low beam? I currently have full halogen headlights and the low beam sucks even after upgrading to the most powerful (yet still in the legal range) low beam light.
Mk8 Fiesta already has a projector lens for low beam.  Unless lighting specs are different in your location?
I live in The Netherlands, the mk8 also comes without projector lenses.
In that case, it should be possible to just swap the light clusters.  You may need to change some settings using Forscan if the new lights have a different setup for DRL's or anything like that.  Obviously they need to be LHD so you can't just buy a set from the UK unfortunately.
