SYNC 1 reset
Hello.
I am trying to do a SYNC 1 reset for my Ford Focus Titanium 2011 MK3 but it is not letting me do it. I tried holding the volume down and seek right button on my steering wheel for 10 seconds and nothing has happened. What can I do and is there any other way to do it because I really want it done ASAP.
Thank you very much.
Sync 1 was introduced after approximately 06-2012 so a 2011 Focus MK3 does not have the SYNC 1 system. It will have the old Bluetooth/Voicecontrol system instead (same connectivity system that was also used on the Focus MK2.5).
Why do you want to reset the system?
Apart from resetting the connectivity system to factory settings there is no way to reset anything. The system consists of several modules (Bluetooth/Voicecontrol module, ACM and FCDIM). Each module can be rebooted using a suitable diagnostic system but this only makes sense in particular cases where a reboot is required (for example when the module configuration has been changed and the particular module needs to reload the configuration).
