Help Required
Can anybody help?
60 plate Titanium 5 door (with new Sony Radio).
On my 2008 6.5 Fiesta I was able to programme the unlocking of the car doors to just unlock the driver's door with one push of the remote, and all of the doors with a second push of the remote, but on the new one the Handbook says I can programme the central locking to do the same as the old one.
I went through the book and it does not tell you how. I then telephoned the Dealer who said it has to be done on their Computer. I took it to the Dealership who in fact could not do it; they telephoned the Ford Technical Department who said it cannot be done on this model. Has anybody found a way round this, or can give me any advice, as I think it is a retrograde step, not to be able to just unlock one door.
Thanks,
Kristal
Hello again... nice to see you back :)
Off the top of my head, it can be done through the car menu. Either that or I'm imagining it!
If it can be done, it's under Menu and then something like vehicle settings. Just have a good root through the menus :)
Hope that helps!
P.S. Pics of the car??
Unlock the car. Press and hold both the lock and unlock buttons for about 7 seconds. The indicators will flash 3 times.
This works on my three door so should work on your 5 door
That's what my dealer told me too.
ALP1101 thanks,
I did try all the menu's before I contacted the dealer and there were none that would do it
Fordpartsman,and Mark T,
thanks for that,and yes it did work,should have thought of that one as thats what i had to do on my Mondeo,I did try that on the 6.5 Fiesta and it didnt work,had to use the menu's..........so I thought i would have to use the menu's on the MK7..........wrong........... so thanks guys, I think Ford Technical Dept need to get its act to-gether as I will be contacting the dealer to-morrow to tell them "how to do it",which will be interesting especially from a female......lol
Best wishes
Kristal
I have just tried this on mine but it doesnt work... ?
Anyone know why?
Anyone know why?
It works on my 58 plate titanium 3 door with Keyless power/lock. Pretty much as above.
1. unlock the car.
2. press the lock and the unlock key
3. wait 6 to 7 seconds and the door locks fire and there where only to indicator flashes on mine.
standard use after that as one press of the unlock drivers door only and press again to unlock the passenger door
The door button for keyless only unlocks the drivers door and cannot be double pressed to unlock all doors.
Nice to see you back Kristal, you took the plunge with a MK7 then!
Hi fordpartsman
Thanks for the great tip. :)
If you wanted to return it to 'default' (one press opens all doors) do you repeat the process again? If not, then how is it done?
Thanks, BHeart
