Turbo oil leak!
Good morning all,
Well this morning I’ve set my new car of only 2 weeks up on my ramps to change the oil. Had an inspection underneath and I’ve discovered something which I wish I hadn’t, a leaking turbo. Is this really bad? 😬😧😢
21 minutes ago, Pburgess2208 said:
Is this really bad?
No.
Looks like the weld might be cracked on the drain pipe?  They're only £60 new from Ford if you do need one.
Genuine Ford Sigma 1.6 Fuel Tank Filler Door Drain Tube 1891941 | eBay
If that's just an optical illusion then it may only need a new gasket.
Genuine Ford Turbo Oil Drain Return Pipe Gasket Petrol & Diesel Engines 1331076 | eBay
Tom you’re an absolute legend. Thank you man. I really appreciate it ✊🏻❤️
