Focus Mk2 tdci ACregass
Hi all looking a bit of advice on regassing Aircon  example type of fitting hose and best place to source refrigerant cheers
Unless you have the proper equipment you'd be better getting it done properly by a profesional. Its not just a case of filling the system up, it requires emptying and subjecting it to a vacum to chech for leaks. Then the correct amount of refrigerant has to be put back, usually by weight. Do you have those facilties ? If no then get it done properly. And there are two different types of gas, you cant mix the two.
And the right amount of oil with leak detection dye etc.
Agree with @Delboy777 despite the cost (leak detection by vacuum is a must before refilling) but gas cylinders etc are also expensive see ebay if you must?
Go to KwikFit or similar. A/C testing and regas for around £70 for a 2009 model
It will be double this price if your car is post 2014, as they use the more eco friendly gas. Not sure what you have as thee are two years in your profile, 2009 / 2018 ?? R134A / R1234YF gasses.
Heading of the post: Focus Mk2 tdci ACregass
So I would say it is a 2009 model, which uses the cheaper AC refrigerant.
So why have Ford year 2018 in there ? Asking for a friend 😁
Possibly because the OP also has a Fiesta ST line which is a 2018
Just noticed the OP is from my neck of the woods, plenty of 'proper' places to get an affordable re-gas. You don't want to mess about with that stuff, get it wrong, and literally you'll go blind...
Thanks Guys will check out prices at local area I think cheers for Advice much appreciated
