Focus cc roof issues
Hi can anyone advise, 2015 model roof not opening, no light on button when pressed
There are approximately 12 sensors and 8 motors for the roof. I assume that you have already checked the fuse for the roof.
You need to use FORScan to read the DTC's so that you can find out what the reason is for the fault.
A 2015 Focus CC does not exist since production of the Focus CC stopped in 2010.
This fault can be literally anything from a defective sensor to a faulty hydraulic unit. I suggest to have a proper diagnostic performed using a Ford specific diagnostic system. Generic diagnostic systems will not show the manufacturer (Ford) specific DTC codes and usually cannot even diagnose the roof system.
Note that finding someone who actually has knowledge and experience to work on the Focus CC roof system is very difficult. Even Ford dealers do usually not even want to get involved with these. From my point of view your best bet will be a convertible roof specialist.
Also be aware that many parts of the Focus CC roof and window system are no longer available from Ford. Some parts can be obtained from aftermarket parts suppliers while others can only be obtained from scrap yards or specialized companies that can refurbish/repair existing parts.
On 4/6/2024 at 5:30 PM, unofix said:
The problem with the Focus CC roof keeps coming up on the forum from time to time. Take a read of this thread and then use FORScan to find out which of the switches is not operating correctly.
https://www.fordownersclub.com/forums/topic/135966-focus-cc3-cabriolet-roof-problems/#comment-941890
Folding Roof Sensors FORD Focus Cabriolet 2006-2010 (CA5) (7zap.com)
On 4/22/2024 at 8:13 PM, unofix said:
There is a company that specialises in roof repair in Chester called Hoodtech run by a young guy called Charlie. All he does is soft tops and hard tops, manual and electric. Knows a lot about the Focus CC roof.
https://hoodtech.co.uk/
Hoodtech know all about the Focus CC roof problems.
Thank you ill try the fuse first, is there also a relay switch for the roof ?
What year is your car and I can check ?
It's a 2015 model
It's a 2015 model
Sorry but that's just not possible. The last Focus CC were made in 2010
Sorry my mistake it's a 57plate 2007
Fuse 17
