Parasitic drain 2015 Titanium X
Hey all
Went out to the car last week and she wouldnt start just ticking a bit , found battery at 10.7v , it had a ford sticker on it , so im guessing its the origional battery . So i ordered a new one , fit it and all seemed ok. Went out this morning and it wouldnt start again , the wife noticed the little light under the driver wing mirror to be on and the side light drivers side to be on . Also when i tried to lock it the mirrors didnt close inwards. So i went into the car and took the lights off auto and onto off. Car the closed properlyt and hey presto , the car also started . But i cant get this to replicate.
I took some voltages just after turning off the car and closing it letting it go to sleep :
13.53pm - 12.64v
13.54pm - 12.63v
13.55pm - 12.62v
13.55pm - 12.61v
13.5pm7 - 12.60v
13.57pm - 12.59v
14.00pm - 12.62v
16.40pm - 12.50v
That seems like a sharp drop to me on volts in a very short space of time , considering it should be at aaround 12.7v on rest , i had some crocadile clips leads coming for my multimeter tommorow , so can hopefully find a parasitic drain  , but has anyone every come accross anything like this before ?
Ford focus 2015 titanium X 2.0ltr , start stop
also to add , whilke running the alternator is supplying around 13.5v to the battery , does that seem a little low ?
New battery was fitted yesterday , and showed 12.7v before i put it in the car .
TIA
That actually is exactly the correct amount of volt drop in the time frame. It discharges exponentially and will start to level out at around 12.45V after which it will slowly drop over a few days.
A battery disconnected from a vehicle and fully charged will not be more than 12.65V after 12 hours. The battery contains 6 individual cells, each one is 2.1V With the battery connected to the vehicle and a typical standby current draw of 30mA it will discharge down quickly at first.
The vehicle is equipped with a variable smart charging system. At a fast idle (950rpm) the usual vehicle voltage will be approximately 13.95V but this will change depending on the state of charge of the battery and also what equipment is in use at the time.
hi
Thanks for that , i have just learnt about the "smart alternator" and it made sense why im getting those voltages.
The battery was down to 12.44v at 19.55pm
Ill see what i can find out tommorow as something was definatly draining the battery this morning!
