Retro fitting the missing High Tone horn to the Mk4 Focus
Hi All,
I done this retrofit some months ago to my 2020 ST-Line X, and never took any pictures, so when my misses got herself a 2020 Vignale last year, I bought the parts required for adding the high tone horn, but up until about 5 hours ago I could not be bothered fitting it, I managed to take a few pics so here goes.
Hardware required:
High Tone Horn and bracket - you can find these on eBay for around £25-£30, the engineering part number you require is JX6T-13801-AB
Horn adaptor cable - I got mine from eBay - PA Products - Pre Wired Horn harness
Some shotgun cable around 20/22AWG from Ali Express
Split 8mm plastic conduit about 5metres
You will need to modify the adaptor cable to give you more length of cable to reach to the passenger side, and where to feed the cable is a space below the bonnet latch that has plenty of room using a wire coat hanger to pull thru.
