Engine Light
Hi All,  How can I remove the engine warning light on a 2003 fiesta. I tried a obd11 Diagnostic tool but it will not remove the light.
Forscan.
FORScan:
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
OR
For diagnostic use only:
Search Tag:   FORScan123
your sentence is constructed in a way one can misinterpret - if you want to remove the bulb ! or for it to stop being illuminated, lots of ways can achieve that,
I guess you meant, the EML has illuminated and a quick check with a cheap tool hasn't helped - you don't extinguish the light with a tool - you use the tool to try and help inform you of the potential faults, then you get them resolved and the car realises, and it turns the light off when its happy
budget tools are of little use, budget adapters a waste of time... they can sometimes give a clue, but very quickly you'll want more info or more capability, or when the car is fighting you'll need to see everything using tools like the ones they suggest above
Thank you all,
I have managed to extinguise the engine light. I used another diagnostic tool which cleared a fault i had, and the light has gone off.
