Ford Fiesta 1.6 TDCi TZJA – Persistent black smoke after sto
Hello everyone,
I'm experiencing an issue with heavy black smoke on my Ford Fiesta 1.6 TDCi 95hp (engine code TZJA), model year 2013 (Euro 5).
📋 Symptoms observed:
Significant black smoke at idle when revving the engine hard.
Noticeable fuel overconsumption (+1 to 1.5 L/100km).
Slight loss of power sensation.
No engine light (MIL) and no active DTCs with FORScan.
🛠️ Background:
Stage 1 remap performed in 2021 by a professional tuning garage ➔ immediately noticed very heavy black smoke post-remap.
In 2024, I asked the same garage to flash the car back to stock.
Black smoke is still present, although slightly reduced compared to Stage 1.
I seriously suspect that they might have flashed a 1.5 TDCi file (75 or 95 hp) instead of the correct 1.6 TDCi DV6D file.
🔍 Diagnostics and tests already performed:
New MAF sensor, new MAP sensor, and smoke leak test ➔ all air system checks out fine.
All four injectors replaced (reconditioned and bench-tested).
EGR valve cleaned (ultrasonic bath).
DPF differential pressure OK, no clogging detected.
Unable to perform a static regeneration (FORScan returns "Too Soot Load" error).
ECU file read and analyzed using KESS V2:
DL LINK https://we.tl/t-BXfmbMZ5F2
MAF Desired extremely low (1–3 g/s, even under heavy acceleration),
📈 PID Observations from FORScan:
Rail pressure ➔ reaches 1600 bar under full load.
MAP sensor ➔ correct turbo pressure (~210 kPa at 3000 rpm).
No DTCs retrieved during auto-tests or driving sessions.
Open questions:
Is it possible they accidentally flashed a 1.5 TDCi map onto my 1.6 TDCi engine?
Why is the MAF Desired value so low (1–3 g/s), even without triggering a DTC?
How can I formally confirm whether the calibration actually matches my original 1.6 TDCi setup?
Has anyone else encountered similar black smoke issues without any fault codes on this specific engine?
Thanks a lot in advance to anyone who can help!
Any experiences or suggestions would be highly appreciated.
Kevin
Are you in the Vatican city by chance ? 😉
Hello, i'm from France , in the south 🫣
Someone can share stock map ecd17c70 DA6A-12A650-NC O 281 031 531 ?
I can't find on internet. With the stock map I will be able to compare with mine.
Cordialy
