door seals
I need to replace  the rubber door seal  front passenger side of my Ford focus Mk2 59plate diesel estate car  look on ebay  so many adverts  can you recommend  a  supplier WHB
The Ford store is the most reliable seller.  They can also confirm the correct part using your reg before ordering.
I'm not sure whether you need the inner or outer door seal so have linked both below.  (They are not cheap!)
Genuine Ford Focus MK2 Front Door Weatherstrip Seal 1534918 | eBay
Genuine Ford Focus MK2 Front Door Opening Weatherstrip 1495865 | eBay
tom put detail of my car  into ford store   the two part numbers wont fit my car My car is upgrade Mk2 59 plate 1.6 diesel estate car  109  Zetec WHB
The ebay compatibility chart can't be trusted.  I did get those part numbers for your current car, but can't guarantee they're correct.   If you send your reg to the Ford Store by ebay message they should be able to check the current parts catalogues to confirm.
