Focus ST Edition 2025
Hello All, I need some help. Vermin has chewed a connection to exhaust gas temperature sensor bank 1 sensor 1 on above car.  As usual in the worst place I.e the actual sensor and connection is fine, so i cannot simply get a new sensor.  It's where that sensor actually connects to, which is a connection block that looks to be connected in some way to the front subframe.  They have took away about 10 cm of wiring so not only is it hard to get to the wire as its on top of the subfrane with little space but it's got no wire left on the connection block.  So I guess I need to find a scrap wiring loom, snip a section of and then somehow try and make a connection with bullet connection or alike.  Does anyone understand what connection I am talking about and what cars would have this connection block on, so I can start ringing around scrap delears ?.  Image attacked, Thank you
and you are looking for a scrap wiring harness ?????? 🤔
Yes, I expect so, the area being mentioned, so I can get the connection and about 30 cm of wiring from it.
