Ford Focus passenger side trim under windshield coming off
   I have a ford focus 1.0 eco boost.
The trim under the windshield on the passenger side is coming off. Wondering if someone else has had a similar problem and how easy is it to fix.
Pictures attached.
Thanks,
Jacey
Never seen that on a Focus before.  It's not a waterproof seal, it's only a bit of foam with adhesive backing to stop the dash squeaking against the screen.  You won't be able to fix it properly without removing the dash or screen.  Just try to push it back in the gap as straight as you can with a thin but wide object.  There's probably something in your kitchen that would do the job.
