Loose Bonnet??
Ok I shut the bonnet earlier and U placed my finger under the recess between the bonnet and small grille and I can move the bonnet up and down on the latch a little!! I thought I might of not shut it properly, so I reopened it from inside the car and slammed it and its still the same!!
I havent noticed this before!! Is this ok?
Should be 2 rubber adjusters/dampers under the bonnet on the left an right side just screw them out to take up the play.
I had the same on my mk 6, just have to move the catch up a little bit, don't forget to re attach the bonnet release though, it's quite difficult to put back on with the bonnet closed ;)
Thanks guys, I adjusted the rubber stops and its now fine :)
