Focus MK2.5 AC clutch P0645 problem
Hi guys!
2 weeks ago my pressure switch sensor on the steering pump was died and leaked oil everywhere, i changed the sensor, its ok, but since then the AC wont work (Digital AC). DTC shows P0645 AC Clutch relay problem. The relay is good i checked it, the gas enough in the system. The ventillator starts when i turn the AC on, but the clutch wont  engageing.  I dont know where to start, change the AC clutch maybe or how can i check the clutch is good or not? Maybe the compressor died? Before the incident the AC is work fine,i think the hydraulic oil soak the compressor/clutch.
Thanks in advance!
2008 Ford Foucus MK2.5 1.6i 74kw SHDA
