2013 Focus losing power
Hello, I have a 2013 eco boost focus and have started to lose power. It is fairly noticeable as I drive other cars however not everyone can realise it. Speaking to my father in law he said it will be a DPF filter (or similar) however I am unsure as it is a petrol and I don’t think this model has a particle filter. The garage I went to said to try redex to clean the system however I am wondering if anyone else has had a boost issue before and how it was fixed.
for reference it is all fine on the flat, but uphill and at higher speeds the engine struggles.
You are correct, that model does not have a GPF (gasoline particulate filter).
The catalytic converters do clog up on them though, so you can try cataclean on it.  I wouldn't bother with standard Redex personally.
If it was a boost issue then I would expect a warning light or message with an 'underboost' fault code.  So I'm not convinced it is a boost issue.  You could check the one-way valve on the vacuum pump, as the diaphragm fails regularly in there which prevents enough vacuum reaching the turbo actuator.
That is the fault code, couldn’t remember what it was! Other forums have suggested a vacuum pump valve so will give that a go. Cheers
