Fuel and Temp Gauge Overreading
Have 1.6TDi Focus Estate. Nov 2007, 150K miles.
The Fuel and Temp Gauges appear to be overreading. Thermostat and electric fan all OK.
Guess it must be an electrical fault.  Maybe a dry joint, faulty regulator or bad earth.
Would appreciate any ideas on where to look first.
Kind Regards
Brian
File attached shows gauges with cold engine, before starting with ignition on.image.thumb.jpeg.7ebfb656ede1683339a6b678c501f1d8.jpeg
How long have you owned the car?
Did you buy it in this condition? Has it just started happening recently?
The cluster could  have had it's poor soldering repaired and the needles have been refitted incorrectly.
I've never seen this particular fault before, but could it be symptomatic of the age old 'instrument cluster' fault and it needs a re-solder?
My brothers car, he is currently working in Middle East. Owned it for about 4 years.
Gauges were working fine. Can re-solder myself, I'm an electronics engineer.
Next question, how do I remove cluster?
It's not that issue then, it's something else.
Just try going into engineer mode (hold trip reset whilst turning on ignition) and the gauges will perform a sweep, they may reset
Before starting, pull wheel as far towards you as it'll go, and as far down as it'll go...
Cheers Dave, that has cured the problem.  Really appreciate all help. God bless car forums.
Brian
