Rear light mk4 2022
I have managed to reverse into a pole hedge and it smashed my passenger rear lights on focus.
I seem to find lots of the part number 13A603 but not SB on end.
What does the SB stand for? Would a TB etc do same job?
Thanks in advance!
It's not the same light, so no is the answer.
The very last letter 'B' can be different, for example 'C' or 'D' or 'E' but not 'A'
eBay: https://www.ebay.co.uk/p/5065038675      or     https://www.ebay.co.uk/itm/286102638718
The light is only used on a RHD Focus Vignale as far as I can tell, so there won't be many about.
Thanks yes seems to be very little around, would a JX7B 13a603 sb be the same light?
The JX7B part wouldn’t work as it’s for an earlier model year
Appreciated
So I need the outside light to, mine is a NX7B-13405-HB
I Have found a NX7B-13405-HC
Thats should be a match then?! Apologies I am new to this world
NO !! 🙁
I thought I'd made it clear in my first post, but obviously not. My 'bad' I guess.
You need the following part: NX7B-13A603-SB
The ONLY alternative part that will be a match is:
NX7B-13A603-SC
NX7B-13A603-SD
NX7B-13A603-SE
NX7B-13A603-SF
NX7B-13A603-SG
No other combination of letters or numbers will work. There are at least 12 versions of the light unit and they are not interchangeable. Some are only for Right Hand Drive (RHD) models and some are for Left Hand Drive (LHD).
Some lights use full LED, some use full filament lamps, and some use a mix of LED and filament lamps.
Lastly some lights are for Estate cars and some are for Hatchbacks.
1 minute ago, unofix said:
NO !! 🙁
NX7B-13A603-SC
NX7B-13A603-SD
NX7B-13A603-SE
NX7B-13A603-SF
NX7B-13A603-SG
I stated in the comment above this was for the outside light and the code on my outside light.
Not the original boot light. &nbsp
The only difference on my outside light is mines a B I’ve found a C. Apologies for confusion
Image of my light attached
So you need two lights, both the inner light and the outer light 👍
Yes you can replace the: NX7B-13405-HB  with the newer revision NX7B-13405-HC that will be fine.
Yes like I say apologies.
Thankyou
