Throttle body part no. ?
Hi , help needed which bit is the part no. For throttle body ? And do I need to match up the long numbers under the 2S6u-FA ?
tia
The base part number 9E926 if you contact your local Ford dealer parts department you will need either the VIN number or a calibration number that is usually affixed to a door jamb. It’s location might be different in the UK. I would strongly recommend using a Ford original component for this one.
